cc306 or close to it, .... in here
Old Jan 22, 2004 | 08:40 PM
BadAssed93Z's Avatar
how high are you guys reving with your cams?what are the specs and where is your peak power, and what is your redline/ rev limiter set at?
thanks a lot
still trying to decide.
Old Jan 22, 2004 | 10:28 PM
fireman's Avatar
I rev to 6500 at the track with my CC306/1.6 rockers, I can't tell you peak power because they only dynoed my car to 5600rpm.
Rev limiter? I think its at like 7100 or so.
Old Jan 22, 2004 | 10:36 PM
FacelessZ's Avatar
What are you guys with the xe 230/236 setting your rev limiter at?
Old Jan 22, 2004 | 11:15 PM
slashz28's Avatar
c306, rev limiter was at 6800, **** pulled strong all the way. before the cam, you could feel the power fall off in the upper ranges (5500 or so). after the cam, it pulled straight to 6800 strong.
Old Jan 22, 2004 | 11:21 PM
HesterZ28's Avatar
I shift my cc306 @ 6500
Old Jan 22, 2004 | 11:26 PM
FacelessZ's Avatar
What would be a safe shifting point with an XE 230/236, or a CC306, if I use EX-612 springs with 1.6 rockers...?
Old Jan 22, 2004 | 11:45 PM
MTL_Z28's Avatar
I can attest to that
BTW Tommy, clean out your PM box.
Old Jan 22, 2004 | 11:49 PM
96ta(nick)'s Avatar
I am having my limiter set to 7k and will get a dyno chart to decide when to shift
Old Jan 23, 2004 | 12:15 AM
Kain's Avatar
I'm airing of the side of safety and not shifting over 6500. But I know I'd make more power over that.
On stock heads, I made max power at 6100. When I finish putting the heads on, it'll be shoved way higher.
Old Jan 23, 2004 | 12:16 AM
slashz28's Avatar
thanks chief i was wondering why i hadnt heard from you???
Old Jan 23, 2004 | 01:05 AM
hvyss's Avatar
I shift my 230/236XE at 6400 with the rev limiter set at 7200 in the PCM but have a 7000 pill in the MSD6AL.
HVY SS
Old Jan 23, 2004 | 05:55 PM
thanks guys.
really appreciate all the help
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
