CC306 or CC503
Old Jan 11, 2008 | 12:54 PM
clcam97's Avatar
CC306 or CC503
another one of those posts my bad,but im finally rebuilding my lt1 with eagle forged internals,so i decided to do a cam swap as well,my car its a weekend car and emissions are not a concern,i hit the track about once a month,my question is whats the difference oin power that this cams make and which one its more supercharger friendly? i appreciate any comments
Old Jan 11, 2008 | 02:17 PM
Stl94LT1's Avatar
If you are going to supercharge your engine, you should look for a camshaft ground for that application.
Old Jan 11, 2008 | 02:51 PM
BUBBA's Avatar
The answer to your question is the same answer given to the question "which cam should I go with"?
I.e. the answer is based on what you intend to to with the car, e.g., drivability, idle, gas mileage, durability, daily driver, racer, etc.
You can use a blower with just about any cam profile. Most agree that you should choose a cam with a wider lobe separation, e.g. 113-115 degrees so that you get maximum scavenging without pulling the new fuel mixture out with the exhaust stroke when there is too much overlap, i.e, the intake and exhaust valves are open at the same time. Boost increases the push of the mixture in at a higer rate and effectively pushes some of it out the exhaust with a narrow lobe sepation. So after you decide what kind of cam you want based on the above questions, consider getting that cam with a wider lobe separation like 114.
I am by no means an expert on anything, but there are members here who can provide whatever you need.JMHO
Old Jan 11, 2008 | 04:40 PM
slomarao's Avatar
if you want to supercharge the engine than get a cam for it like a xe224/236 on 114. If you going to stay na look into the xe 224/230 on 110 or 112. The cc306 is a very old cam, not to say that its bad but there are newer things around. Theres also a xe230/236 which still the xe design if your still looking into the 224/230. Comp has came out with the xfi grinds now too. So i would also look into them.
As for power, the bigger cams will make more power provided your heads can support them. But with a bigger cam will come more driveability and tuning issues. Good luck
Old Jan 13, 2008 | 01:47 PM
97SS0594's Avatar
i have the cc503 in my 355 and love it... car went 12.8 with a few issues. i also have the GM847 and liked it, im now in the process of swapping the gm847 into the 355... should make an impressive differance
Old Jan 14, 2008 | 11:45 AM
Red96Lt1's Avatar
For FI, make sure you can get all that air out.
Old Jan 14, 2008 | 11:57 AM
rskrause's Avatar
Moderator
Those cams are way different. One is gonna want 6,500+rpm (306), the other less than 6,000 (503).
Rich
Old Jan 14, 2008 | 02:04 PM
clcam97's Avatar
thanks for all of the replies,now i have an idea on what direction to take.
Old Jan 14, 2008 | 04:51 PM
reamo04's Avatar
the best advice I can give you is...read, read, read
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
97SSdude
Aug 21, 2015 09:36 AM
alphaauto
Jul 26, 2015 04:40 PM
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
