is cc306 big enough for my new motor
Old Aug 6, 2003 | 09:47 PM
amean94ta's Avatar
in sig
Old Aug 6, 2003 | 10:18 PM
ibanez6rg's Avatar
I'd go bigger
Old Aug 6, 2003 | 10:43 PM
96z's Avatar
96z
Bigger isnt always better although the 306 is a proven cam. I have a cam with way less duration and slightly more lift and I made the power in my sig....
A solid roller would be the way to go though...
Old Aug 7, 2003 | 06:55 PM
amean94ta's Avatar
thanks and i do know if you go to big you lose because my friend had a stock 350 and put in a lunati 292 avd dur cam and it fell on its face every launch
Old Aug 7, 2003 | 07:01 PM
4drLT4's Avatar
Since it's critical that heads & cam work in unison, it would be beneficial to know more about the heads you plan on bolting up to your new motor. Personally, I'd wait to see what the heads do on the bench, then choose a cam that will complement them. JMHO
Old Aug 7, 2003 | 07:08 PM
amean94ta's Avatar
i could be wrong but i think my cousin said 330 cfm
Old Aug 7, 2003 | 08:16 PM
Farc's Avatar
any one have the numbers for the CC306 lobe lift all Or the link site for the CC.
Thanks.
Old Aug 7, 2003 | 09:58 PM
96z's Avatar
96z
There is no way that is possible with LT1 or even LT4 castings...with a set of AFR's its possible.
Old Aug 9, 2003 | 10:42 PM
zuluman13's Avatar
ttt i would lke to hear more about this as well.
Old Aug 9, 2003 | 11:05 PM
amean94ta's Avatar
i dont know he owns krs machining and he said its possable he is the expert so when they get flowed ill know.
and for the specs on cam my box says (i have 5,000 dollars of parts in my room. adv dur:290 int .307 ext
dur @.050 :229 int .245 ext
valve lift :510 int .540 ext
lobe sep: 112.0
lt1 290 hr-12
Old Aug 9, 2003 | 11:47 PM
4drLT4's Avatar
The only way you're going to pull 330cfm out of GM LT1 heads, is with some VERY skewed flow bench numbers.
StansZ28
Feb 19, 2015 07:39 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
1LEThumper
Jul 14, 2003 12:45 PM
guionM
14
Jun 19, 2002 08:30 AM
