CC305/ported head track results
Old Sep 6, 2003 | 12:43 AM
12SCNDZ's Avatar
I'm finally starting to get the new combination figured out. I'm still using my 95,000 mile unmolested bottom end. The heads are Joe Prince Racing ported, the cam is a CC305.
My car still has a completely stock suspension with the exception of the removed front sway bar...And has NO weight reduction other than the Draglites.
Tonight, at Cecil County Dragway, it went a 12.38 @ 111.9 MPH with a 1.77 60 ft..
The converter still needs more stall...I'm only coming out at 1900 RPMs, on the footbrake.
For a full detailed build list, check the "Stats and Specifications" link on my web page.
http://www.geocities.com/max_wylde/9...re_page_1.html
Frank
Old Sep 6, 2003 | 01:46 AM
neil350's Avatar
Good times, I'm sure when winter rolls around you can get that e.t down some more maybe in the high 11s with some work.
Old Sep 6, 2003 | 04:13 AM
94ta383's Avatar
Looks good. How much you sprayin on the stock pistons?
Old Sep 6, 2003 | 09:16 AM
Fastbird93's Avatar
Joes heads are the shiznit aren't they?? Have you dynoed it yet, and what are your numbers like??? I have his heads with a 224/230 and it rocks!!
Old Sep 6, 2003 | 10:06 AM
Black_Z28's Avatar
Where does it say that he's using Nitrous?
Old Sep 6, 2003 | 10:29 AM
12SCNDZ's Avatar
Spray? It's an all motor car.
Frank
Old Sep 6, 2003 | 11:00 AM
SS MPSTR's Avatar
Screamin' times, Frank.
Old Sep 6, 2003 | 11:02 AM
12SCNDZ's Avatar
How does yours run with the CC305/LT4 head combo?
Frank
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
