Cc Xe 236/242
Old May 24, 2007 | 07:38 AM
  #16
69gto96z's Avatar
What about the XE 230/236?
Old May 24, 2007 | 07:40 AM
  #17
69gto96z's Avatar
Figured I would list my goals. 350 rwhp cam only, daily driven. Want a very noticeable lope so people are like DAMN . Car is a 6 sp with 4.10's, and I dont wanna rev any higher than 6500 tops. I will also be sprayin a 100-125 shot on top of it.
Old May 24, 2007 | 11:19 AM
  #18
speed_demon24's Avatar
Originally Posted by seawolf06
Of course, your results will vary. Don't expect these numbers without at least ported heads. Like I said, though, my runs weren't optimal.
And if you can afford a custom cam like speed demon, then this thread is pointless.
Do you have a dyno graph with RPM's with your combo? I was trying to compare it to mine but it's kind of hard to with it in MPH. BTW get some track times for your car, dyno #'s really don't mean ****, expecially comparing a dynojet to a mustang dyno.
Old May 24, 2007 | 11:20 AM
  #19
If you want to only rev to 6500 tops stick with something in the low-mid 220's duration wise on the intake. CC503, CC305, GM 846, ect. Or go custom.
Old May 24, 2007 | 11:25 AM
  #20
buzz12586's Avatar
cc503 with all the supporting mods will make around 350rwhp through an M6.
Old May 24, 2007 | 12:58 PM
  #21
69gto96z's Avatar
I want to go custom, but cant afford to get a dyno tune right away, and I know with a proven off the shelf cam, a mail order tune can get me almost dead on, then when I can afford the dyno tune, I can get one.
Old May 24, 2007 | 01:18 PM
  #22
mthegodfather's Avatar
CC503 would be best.Great power with a very noticable lope.Your exhaust can also play a large part. Did you hear the lope in the video?
Old May 24, 2007 | 01:48 PM
  #23
SS MPSTR's Avatar
Originally Posted by speed_demon24
Or go custom.
doesn't need custom...a tried and true shelf grind will suit his goals just fine.
Old May 24, 2007 | 03:02 PM
  #24
Notice how I said or go custom.
Old May 24, 2007 | 04:33 PM
  #25
SS MPSTR's Avatar
Or just get an LS1
Old May 24, 2007 | 04:34 PM
  #26
Daniel6718's Avatar
ryan, if i had to do it again, i would have done a 305 in a automatic, and a 6 speed i wuld have done a 306....for roll races it pulls great up top...if i were you and you HAVE to keep it under 6500 then go 305 and be happy...woull like it...if it were me, id do 306 dont worry about bearings in a new motor make sure you pout s stock volume pumpand machine it good, mine was kinda tight, pressure was 80 at wot...and 50 at idle...
keep fresh oil in it also...mine lived 8k miles like that+125 shot...and still kicking today!
Old May 24, 2007 | 05:59 PM
  #27
seawolf06's Avatar
cc503 > cc305.
Here's a list of the most popular cams in case you haven't seen it. Check out the RPM ranges. You'll usually have to shift a few hundred RPM higher than the range, though, so keep that in mind.
http://getonitracing.net/forum/viewtopic.php?t=376
Old May 26, 2007 | 12:34 AM
  #28
Heatmaker's Avatar
Advanced Member
Shhhhhhh we keep that cam a secret around these parts.
I will say this though... the 230/236 revs to the moon as well. So your not escaping much by going to that cam.
If you want a fun cam on stock heads look into the much over looked GM 846, or the ever popular cc503.
Old Jun 1, 2007 | 01:40 PM
  #29
69gto96z's Avatar
What kind of power can i expect with a GM 846, or a CC503 ground on a 110 LSA?
Old Jun 1, 2007 | 08:46 PM
  #30
edunegan95's Avatar
cc305 runs real well on stock motor and has a decent lope to it
MadMaxz28
Sep 4, 2004 06:37 PM
trans9_5am
Jul 16, 2004 06:52 AM
trans9_5am
Jun 30, 2004 03:55 PM
96speed
May 13, 2004 09:52 AM
ninjatertl
Mar 22, 2004 05:18 PM
