CC 306 power band
Old Aug 18, 2004 | 01:45 AM
kacy's Avatar
CC 306 power band
what does the band range
Old Aug 18, 2004 | 01:58 AM
1badasZ's Avatar
Re: CC 306 power band
do a search on it. have seen some people spin way up around 6700 but i dont know for sure
Old Aug 18, 2004 | 07:29 AM
GreenDemon's Avatar
5-7k area.
To take full advantage of it you'll need p&p heads, headers, & better valvetrain.
Old Aug 18, 2004 | 07:34 AM
kacy's Avatar
i have roller rockers,getting new springs ported and polished heads and is goin in my 69 camaro with 411 and a 6 spd
Old Aug 18, 2004 | 07:39 AM
GreenDemon's Avatar
Hydraulic roller, eh? Should be interesting in that car.
The power band should get pushed back down some with more cubic inches, of course, so there shouldn't be any problem with steetability.
Old Aug 18, 2004 | 07:40 AM
n2ceptor's Avatar
http://www.compcams.com/Technical/Cu...ML/198-199.asp
Old Aug 20, 2004 | 01:28 AM
slp223's Avatar
the 306 is a great cam that make lots of people mad. it is not new it is not fancy but it makes great power for an off the shelf cam my 383 make power all over the dyno with it. rwtq is at 350 at 2500 rpm 400 by 3500. hp pulls over 400 from 5200 to 6500 that is a huge power band. peak number are great for racing dyno but dont mean a thing when it come to racing cars. i have yet to see a off the shelf cam put of better number over and over like a 306.
Old Aug 20, 2004 | 09:56 AM
dust6928's Avatar
n2ceptor you beat me to it. i read all the time these guys spinning their engines over 6500 with this cam. depending on what else you have done to the car and how the cam was degreed in, it may pull higher or lower but the truth will be told on the dyno. sure it may work above 6500 but by then you are way past your peak. i HAD a 383 in my old car and when they found it the tack registered the highest rpm and it was 11500. every valve was bent, but it did it. with almost any street cam no matter how big you probably wont see much gain above about 6200. contact comp and let them know what all you plan on doing and they can give you a good idea of what to expect.
MadMav
Jun 15, 2015 09:51 PM
MadMav
Jun 8, 2015 11:38 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Lions3
Apr 11, 2003 10:55 AM
XtremeLt1
Sep 13, 2002 08:50 PM
