CC 305 ?s
Old Oct 4, 2007 | 02:37 PM
rgjr9852's Avatar
CC 305 ?s
I was intrested in buying this cam, It is what comp cams recommend for stock heads. I was wondering what ETs and kind of power people were making with this cam. or if there are other cams better for stock LT1
thanks
Old Oct 4, 2007 | 02:52 PM
hotrod18_69's Avatar
I like this cam, put it in a friends are a few years back.. Its alittle tame for me.. But we went 12.90@109 with full bolt on's 3:73 stock auto..
It was a fun little cam..
Old Oct 4, 2007 | 04:43 PM
sandman2100's Avatar
I run the 305, great for daily driving and no complaints here. Went 12.66 @111 with it and the mods in the sig
Old Oct 4, 2007 | 05:01 PM
wrd1972's Avatar
You should consider the CC503, a bit more agressive than the 305 and satill decent with stock heads.
Old Oct 4, 2007 | 05:04 PM
6SpdLT1Z's Avatar
do you have a idle video by chance?
Old Oct 4, 2007 | 05:20 PM
Nope, but I can get one in a few. Just got out of the shower.
This winter the motor is getting ripped appart. I'm still trying to decide which cam I want. I like my low end with the 305 and I don't go over 5k
Old Oct 4, 2007 | 06:32 PM
ricehammer's Avatar
Here are some LT1 sound clips for ya
http://www.lt1engine.com/soundlib/cam.html
I think the CC305 section is actually the CC503, just looking at the cam durations listed. 224/230, 112lsa is the CC503. BTW - the 503 is a great cam. I really like mine .
Old Oct 4, 2007 | 07:44 PM
http://www.youtube.com/watch?v=Zy2qK00DBvM
Idle at about 950rpm, mild warmup
Old Oct 4, 2007 | 08:09 PM
mdenz3's Avatar
CC-305:
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 230
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Lobe Separation (degrees): 114
CC-503:
Intake Duration at 050 inch Lift: 224
Intake Valve Lift with Factory Rocker Arm Ratio: 0.503 in.
Lobe Separation (degrees): 112
HOT CAM:
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 228
Intake Valve Lift with Factory Rocker Arm Ratio: 0.492 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.492 in.
Looks like it should do pretty well with stock heads, after looking into it I am surprised more people aren't running them.
Old Oct 4, 2007 | 08:43 PM
6SpdLT1Z's Avatar
Cool - I was just currious because I have a similar exhaust setup. (Eldebrock TES -> SLP 2OTL)
Unfortunately for me, the cam swap is a while down the road.
Old Oct 4, 2007 | 09:00 PM
95z28racer's Avatar
CC-305:
CC-503:
HOT CAM:
So peak power would go to the 503 then 305 then hotcam right?
The 503 and 305 seem to be basically the same, whats the peak power difference between the two?
Old Oct 5, 2007 | 08:48 AM
wrd1972's Avatar
It wont be much at all, but the 503 seems to be the more popular mid size cam from searching the board. It is not "big" or even "wild", it is a great streetable cam with no ill side effects. You will see a big difference over the stocker.
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Rittmeister
Aug 7, 2015 01:13 AM
