Cats/Headers Question
Old Feb 16, 2005 | 03:48 PM
brickhoss's Avatar
Hey guys... I think after the positive response to my last question I'm going to keep my pacesetter longtubes... New question though....
What can I do for cats? Do i need to buy cats that fit at the end of the collectors and then hook to the Y-pipe? Or is there another option?
I have to get cats one way or the other, because in MD, they're required. Thanks for your time guys!!!
Old Feb 16, 2005 | 03:54 PM
Bawls's Avatar
Re: Cats/Headers Question
Chop up the y pipe, after each collector have a cat. Have each cat welded to the ypipe.
Old Feb 16, 2005 | 10:57 PM
camaro 22's Avatar
I have a single catco cat comming off my mufflex y pipe and then my borla.
Old Feb 17, 2005 | 08:00 AM
brickhoss's Avatar
Do you think a setup like that would pass MD inspection though? I like the idea of two up front because that's closer to a stock cat setup look... But then again... that's why I'm asking questions
Old Feb 17, 2005 | 10:11 AM
bdc95ta's Avatar
If it where me I would try to run two small one's where that hump is on the passenger's side to avoid ground clearence issues. I don't think that's feasible w/ the y-pipe you have thought. I would recommend that you run them farther down your pipes though b/c they'll have less influence on hp losses.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
