Catalytic Converter system low efficiency Bank 2 ???
Old Oct 25, 2004 | 08:36 PM
Cory_SS's Avatar
SES light on and pulled trouble code P0430. (Three Way Catalytic Converter (TWC) system low efficiency Bank 2)
Should I just replace the cat conv or could it be something else?
Old Oct 25, 2004 | 11:18 PM
Euclid's Avatar
Re: Catalytic Converter system low efficiency Bank 2 ???
More likely that it's your o2 sensor(s).
Old Oct 26, 2004 | 03:50 PM
Cory_SS's Avatar
That's what it feels like to me. It seems like the fuel delivery is whacked. It feels like the gas just shuts off and kicks back in. I'll be going along and I will put my foot in the gas and it seems dead, then all of the sudden it kicks in and takes off. It pulls strong all the way up to 5500 rpm with no signs of there being a problem. It's just the initial push of the gas pedal it doesn’t like.
I just don't see how a cat with low eff. could cause these kind of symptoms.
Old Oct 26, 2004 | 07:06 PM
The after cat O2 sensor code shouldn't affect driveability in any way. There is something else wrong.
First, clear up the O2 sensor code. Switch the left and right after-cat sensors. If the problem follows the sensor (changes to P0420), its a sensor problem. If the problem stays on the passenger side, could be the cat or could be a wiring problem. Sort that out first, then go after the driveability problem.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
4586
Mar 18, 2015 06:31 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
