Catalytic converter code 0420
Old Aug 4, 2003 | 09:11 AM
JBirdSS's Avatar
Just got a service engine soon light...scanned and found "catalyst system efficiency below threshold bank 1...P0420. Can anyone give my suggestions of the fix for this code? Could this be a tank of bad gas or something easy? Which side is bank one? Please respond if you have an idea! Thanks in advance. Jay
Old Aug 4, 2003 | 09:12 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
SUUUUUWEE!
SOUNDS LIKE ITS TIME FOR A GUTTEN' PAW!
then just clear the code
have fun...
Old Aug 4, 2003 | 10:56 AM
"Bank 1" is the left (drivers) side. The code could indicate a dead cat, or it could be a problem with the after-cat O2 sensor. You could swap the after-cat sensors between the right and left sides to see if the problem follows the sensor = faulty sensor, or stays on Bank 1 = faulty cat.
Of course you can't just "gut" the cats on a 96 unless you get "sims" for the after-cat sensor positions, or have the after-cat sensors programmed out of the PCM.
captcorvette
Mar 7, 2015 12:37 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
