Catalytic Converter and Canister Purge Valve questions...
I believe that my 1995 Camaro Z28 has dual cats...one located underneath the passenger seat area and the other that looks like a canister shaped object near the engine compartment.
What is that canister-looking catalytic converter called? Does anyone know the part name or part number for that?
Also, what is a canister purge valve and what role does that play in helping me pass smog? Does something like that need replacement every so often?
Re: Catalytic Converter and Canister Purge Valve questions...
Then when the engine is running, the EEC purge solenoid on a bracket on the passenger side of the intake manifold will open, and pull air through the canister to pick up the hydrocarbon vapors, pull them through the plastic line that runs along with the fuel supply and return lines, through the purge solenoid, and into a port on the side of the throttle body. That way, the air and hydrocarbon purge gets burned in the combustion process.
The charcoal canister can get saturated with liquid fuel, or the charcoal can "wear out". But it isn't likely that this would show up on a smog test. They don't test the air that vents out of the EEC canister.
The catalytic convertors and EEC canister have nothing to do with each other.
squarehead
Nov 21, 2014 08:02 PM
kclarson
Aug 22, 2002 04:04 PM
