Catalytic converter
Old Jun 21, 2015 | 01:19 AM
wbacall's Avatar
Catalytic converter
Does anybody know for certain if a factory GM 1995 Z28 catalytic converter with head pipe is the same as a 1994 catalytic converter. They seem to have different part numbers. Trying to find a replacement GM catalytic converter but only can find one for a 1995. Thanks!
Old Jun 21, 2015 | 08:44 AM
Re: Catalytic converter
The GM parts book has 93-95s with single converter the same part number (export is a different number).
Old Jun 21, 2015 | 09:44 AM
If the 95 is a CA emissions model (RPO "YF5"), and it has an A4 transmission, it will be dual cats, similar to the 96/97 49-state dual-cat system. The 94 CA emissions A4 did not have dual cats.
Old Jun 21, 2015 | 01:13 PM
wbacall's Avatar
Thank you both for the fast reply! Can you tell me what the part number is? Are there any other options that I should look at. I have a 94 with single cayalyst. Trying to locate a new oem catalytic converter. Thanks again!
Old Jun 21, 2015 | 01:22 PM
Manual or auto trans?
I bought my 94 Formula in CA, and the 1994 M6's were all 50-state certified, no CA emissions add-on.
Can't you use an aftermarket cat, as long as it is CARB certified for your year/engine/trans car?
Old Jun 21, 2015 | 02:19 PM
wbacall's Avatar
Automatic. Was originally a 49 state car, in CA now.Thank you.
Old Jun 21, 2015 | 08:24 PM
The GM part is discontinued. You'll have to go aftermarket.
Old Jun 22, 2015 | 12:01 AM
Fatdog2's Avatar
Might stop by R@G brake and wheel on creekside.See Rick the owner.He knows these cars real good.He also owns the exhaust shop next door.His dad had a F-body.He is behind the post office with all the car repair places there.His prices are fair and he is always dead on with any repair.Also the dent removal place down a couple of doors is a God send.Hope this helps.Tell him Jim sent you with the red camaro z28(furniture salesman at Simply discount).
Old Jun 22, 2015 | 12:07 AM
Fatdog2's Avatar
Sorry I had to come back in here but d id you fail smog or something and you need a new cat?How miles on the car? Sometimes it might be the 02 sensors going south.Hope this helps.
Old Jun 22, 2015 | 06:48 AM
There are no after-cat O2 sensors on a 94. The PCM has no way to monitor cat activity.
Old Jun 22, 2015 | 10:04 PM
wbacall's Avatar
Thank you everyone for all the answers and suggestions! I have had to replace the aftermarket catalytic converter every couple of years and was hoping to find a new oe catalyst. Got a new Walker cat and passed smog test today. Thanks again.
mark0006
Sep 14, 2015 12:35 PM
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
