Cat delete
Old Apr 3, 2003 | 11:53 PM
xmatt's Avatar
Question Cat delete
Hi guys of superior 4th gen knowledge,
I was wondering if I could buy a 3 or 4 inch wide pipe, I could unbolt my cat and insert it in it's place. I have a 94 (one cat under passenger) and a wide open borla. What do you guy's think?
Old Apr 4, 2003 | 01:48 AM
chesee48's Avatar
Yea, just buy an Off Road Pipe...Same thing..
Thats what i have..
Old Apr 4, 2003 | 01:57 AM
Calli's Avatar
yah... you could.. i cut my cat off and just welded a pipe in its place
Old Apr 4, 2003 | 02:37 AM
Wild1's Avatar
I have the off road pipe but the exhaust pulses on my single pipe blew the crap out of my muffler. Maybe it was a defective muffler or age... but I put on a new muffler and installed a Dynatech Exhaust Insert Cone to help straighten the exhaust. Has a very nice tone. Don't know if that will help the muffler but I'll do my best to blow out the stuffing...
Old Apr 4, 2003 | 10:37 AM
xmatt's Avatar
...the main question is if I have to weld/unweld the pipe, or if it bolts/unbolts, so I could switch back easily?
Old Apr 4, 2003 | 12:17 PM
Wild1's Avatar
Yes, it is illegal to tamper with the emission equipment. You can only use the Off Road Pipe at the track then must replace it before you ride the public highways.
You can unbolt the pipe at the rear of the pipe using the standard cat two bolts. The front can be expanded and fit over the exit of the collector (that's my set up) and then tightened with a muffler clamp.
That way I can strap on the CAT at the track when I leave.
Old Apr 4, 2003 | 01:23 PM
chesee48's Avatar
I have my shop put flanges on the ends of both the cat and pipe so that i could make it interchangable when i take my test...
so yes, it can be done!
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
