cat convertor problems
Old Jul 26, 2003 | 01:02 PM
dan6441's Avatar
i have recently lost some power in my car. i heard a rattling noise coming from underneath. i have been told it's my cat converter. i want to know should i replace it or get it cut out. and if i do get it cut out how do i avoid having the engine light go on? thanks for the help!
Old Jul 26, 2003 | 01:04 PM
madwolf's Avatar
I'm guessing you have a 93-95 since you're talking about one cat. If you remove it, you won't get a light.
Old Jul 26, 2003 | 01:10 PM
dan6441's Avatar
no it's a 96 z28
Old Jul 26, 2003 | 01:12 PM
madwolf's Avatar
Well, I never heard of anyone running a cat on one side and no cat on the other. I'd recommend removing both if one of them is bad. Or replace the bad one with a new cat.
As for the light, you could either have it reprogrammed or buy an o2 simulator.
Old Jul 26, 2003 | 01:19 PM
dan6441's Avatar
ok i would remove them on both sides but i live in canada so i don't know if it could be reprogrammed here?
Old Jul 26, 2003 | 05:05 PM
EviLBoX's Avatar
If you remove them you can just put some O2 simulators on the back two O2 sensors, you don't need to get your computer reprogrammed. It will just send a signal to the computer saying that the cats are still there.
Old Jul 26, 2003 | 06:35 PM
dan6441's Avatar
where do i get or order a o2 simulator?
Old Jul 26, 2003 | 06:40 PM
TechCam97's Avatar
Any online performance shop should have them. Check out Summit Racing.com
Old Jul 26, 2003 | 06:51 PM
dan6441's Avatar
which one could i order:
o2 simulator 1box $44.95 or
o2 simulator 95-96 GM FBody Easy Plug-In Installation $88.95 (pair)
Queens94z28
Mar 23, 2015 08:06 AM
Dec 1, 2014 08:08 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Darth Xed
12
Jun 27, 2002 07:46 PM
