CAT/02 sensor question
Old Jan 12, 2004 | 09:48 AM
fuzzyz28's Avatar
Question CAT/02 sensor question
My car is a 94 Z28. The engine is stock with the exception of a CAI. I have a aftermarket muffer, but other than that, the exhaust is stock also.
Here's my question. Do you think it would be worth the money to get new 02 sensors, and a new cat (probably Random Tech)?
I don't race the car, I'm just trying to keep is running as good as possible.
Also, it's got 93,000 miles on it and to date, it still runs great.
Thanks for any opinions.
Old Jan 12, 2004 | 09:58 AM
gamecockfan04's Avatar
O2 sensors should be replaced about every 100K, but as long as the cat isnt clogged Id leave it alone, or if you dont have emissions, gut it or take it off.
Old Jan 12, 2004 | 10:45 AM
Fuels94TA's Avatar
Is your car running rich? idle problem? If it's running fine I wouldn't change them at all. Ever heard don't mess with it unless it's broken.
Vinny
Old Jan 12, 2004 | 11:19 AM
fuzzyz28's Avatar
The car actually runs great. I'm just going through and doing preventive maintainence.
Maybe a stupid question, but how could I tell if it was running rich?
would bad/worn 02 sensors have an effect on that?
Old Jan 12, 2004 | 11:35 AM
If you're running rich you'd be able to smell gas in the exhaust and probably under the hood and maybe notice a slight stumble/hesitation at idle. O2 sensors are normally the cause of running rich.
Old Jan 12, 2004 | 11:48 AM
fuzzyz28's Avatar
Old Jan 12, 2004 | 12:27 PM
terlox's Avatar
I've been told that bad O2 sensors can cause the car to burn oil, run sluggish and decrease mileage. Is there any truth to this?
Also, how often should the cat be replaced? Mine's going on 123,000 miles. Is there any plain and simple way to tell if it's clogged or going bad?
Old Jan 12, 2004 | 12:59 PM
Bad O2 sensors can cause your car to run sluggish and it can decrease your mileage due to running rich (sensor is telling the PCM to use more fuel). Ive never heard about it burning oil and dont know how thats possible. As far as the Cat, there is no way to check it. If your car backfires alot and when you mash the gas it doesnt want to go its probably time to replace it, but a cat should last you almost the lifetime of the car(over 150K) before needing replacement, unless its been running rich for a while.
Old Jan 12, 2004 | 02:01 PM
Fuels94TA's Avatar
another way to test a converter is a temp test from inlet to outlet. All muffler shops will do this test, that's how they know if a cat is cloged up.
Vinny
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
