Cast iron head lt1
Old Oct 1, 2010 | 01:33 PM
drennon1's Avatar
Cast iron head lt1
I'm pulling my 94 lt1 and while I am building It I want to drop in a vast iron head lt1 out of a 96 impala would the cam from my aluminum head engine add any performance to the cast head motor? Any difference in the engines other than the heads?
Old Oct 1, 2010 | 01:40 PM
RamAir95TA's Avatar
Iron heads flow marginally better, but that is easily offset (and then some) by the added weight.
Old Oct 1, 2010 | 01:55 PM
drennon1's Avatar
I know they flow slightly better this is just a cheap motor to keep me on the road until I build the one that's in it which has a rod knocking. My main question is would the cam be worth trading out since I won't be reusing it?
Old Oct 1, 2010 | 02:11 PM
razor02097's Avatar
Even if the cams are different...
IMO since it is just a build gap motor I wouldn't bother putting any more money into it than absolutely necessary... Remember swapping cams means new gaskets, seals and time.
Old Oct 1, 2010 | 04:35 PM
Cams are different:
But why change it.... you will have a lower compression ratio with the Caprice engine, and the iron heads will not allow as much timing advance as the aluminum heads.
Old Oct 2, 2010 | 08:53 AM
drennon1's Avatar
Is the compression ratio the same in both motors? If I swap the heads off my bad engine onto the good one. I am going to be driving this around for probably a year or so. I am going to replace all the gaskets in the engine before I swap it cause It has a slight oil leak in the front.
*Emilia*
May 13, 2015 09:05 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
