Cast heads and CC306
Old May 9, 2005 | 06:06 PM
Dannysz28's Avatar
Im going to be running a cast head on my 383 with a CC306 cam and 1.6 rockers. I was wondering if anyone knew what valve spring that i need to use on this setup. I know the same ones on the aluminum heads wont work on the cast heads. I got a good deal on the heads is the reason that i went with the cast.
Old May 9, 2005 | 06:19 PM
sw89lt1's Avatar
Re: Cast heads and CC306
you will also need to have screw in studs installed. the pressed in studs will pull out with that cam.
Old May 9, 2005 | 07:27 PM
Dannysz28's Avatar
Thanks for the info
Old May 9, 2005 | 07:53 PM
SStrokerAce's Avatar
The springs don't care what the head is made of, same ones will work.
Old May 9, 2005 | 07:56 PM
sw89lt1's Avatar
i don't think the spring diameter is the same on iron and aluminum heads.
Old May 9, 2005 | 09:32 PM
Dannysz28's Avatar
The guy i talked to from crane said i will have to machine the head. He said something about the spring height was different. He said the crane valve spring and lock set thats on my aluminum heads would not work. I guess he is talking about machining where the spring sits.
Old May 9, 2005 | 09:55 PM
That's not hard to do IF the head is off the motor... There are some cutters you can get from Isky and Comp that will machine the spring pockets for you.
Bret
Victor Lamb
Aug 26, 2017 02:52 PM
nathan221432
Parts Wanted
Mar 29, 2015 08:29 AM
pimpss96
Feb 12, 2015 01:28 PM
kizz
31
Sep 4, 2002 01:17 PM
