carries
Old Mar 3, 2003 | 02:44 PM
radarb8's Avatar
carries
I have a torsen carries that I want to put in my '95 z28 . If I pull the carries out and pull the ring gear off to put on the torsen carries and reinstall with the same shims will this work or is this better left to profesionals
Old Mar 3, 2003 | 03:48 PM
Re: carries
That would be carrier... and once you pull the rear apart, it has to be set back up. Unless you have the tools to measure bearing preload, pinion depth and backlash, leave it to a professional.
And, this belongs in "LT1 Tech"...... moving it there.
Aug 7, 2015 08:52 AM
timmy39120
May 2, 2015 05:12 PM
cmsmith
Mar 24, 2015 02:28 PM
ChrisFrez
Mar 22, 2015 09:12 AM
Faccnator
Feb 9, 2003 05:45 PM
