carbed lt1
Old Dec 17, 2007 | 02:32 PM
93v8clone's Avatar
carbed lt1
ive been thinkin of of carbin the lt im tired of harrness probs with it its a standalone system on it now. what would have to be rewired if i run a carb on it ive got aftermarket gauges on it now all i care about is lights/ charging so on and so forth
Old Dec 17, 2007 | 03:08 PM
The PCM has nothing to do with the lights, charging system, or dash gauges other than the tach and speedo. It controls the ignition timing and the injection. If you add a carb, you have replaced the injection system. If you add a distributor, you have replaced the ignition timing controls. If you want your speedo to continue to work, you can leave the stock PCM in place and it will continue to work. Or you can buy an interface box to connect the VSS directly to the speedo/odo.
Old Dec 17, 2007 | 07:16 PM
93v8clone's Avatar
any real downsides to it ?
Old Dec 18, 2007 | 02:17 PM
96 mikez28's Avatar
yes...you will have a carb lol
Old Dec 18, 2007 | 07:01 PM
93v8clone's Avatar
and whats wrong wit carb? had nuthin butr good luck with em
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
