Car won't turn on
Old Dec 28, 2010 | 02:00 PM
Cobian2890's Avatar
Car won't turn on
I have a 1995 Camaro and when I try to turn on my car it just cranks but never fully turns on unless I hold the gas down. I have a k&n filter kit but I took off the filter and forgot to pit it back on. Do you think this would cause my car not to turn on? Thanx in advance
Old Dec 28, 2010 | 03:14 PM
Re: Car won't turn on
Let's make sure we're all on the same page. When you turn the key to start the engine, the starter engages and the starter cranks the engine over. The engine will not actually start to run, unless you hold the accel pedal on the floor while cranking it with the starter. Once it starts, you can release the pedal, and the engine runs normally.
IS THE ABOVE AN ACCURATE RESTATEMENT OF YOUR PROBLEM?
A missing air filter will not cause the engine not to start. If you removed the complete K&N CAI, including the MAF sensor, then you might have a problem.
Old Dec 28, 2010 | 07:19 PM
Cobian2890's Avatar
Yes correct except for the last statement that the car's rpms are at 1500 at idle and they go up and Down for no reason for the first 5 minutes and if I try to go anywhere my car stalls in those first couple of minutes but after it runs fine.
Old Dec 28, 2010 | 10:42 PM
The PCM is programmed to elevate the idle RPM when the engine (coolant) is cold, but not to 1,500 RPM.
When you hold the accel pedal on the floor, that puts the PCM into "clear flood" mode. It cuts fuel from the injectors, and lets fresh air clear the flooded condition. Appears you may have leaking injectors, flooding the cylinders. Or its richening the cold start A/F ratio too much. Possibly a problem with the coolant temp sensor for the PCM (the one in the water pump housing).
Old Dec 29, 2010 | 08:51 PM
ram air camaro's Avatar
just like injuneer said start with the coolant temp sensor their cheap and u can do it your self
Old Dec 29, 2010 | 09:19 PM
Rather than just start playing parts replacement roulette (you will always lose), test the sensor:
http://shbox.com/1/4th_gen_tech2.html#ect
Old Dec 29, 2010 | 09:38 PM
..DAMN..'s Avatar
Does the car throw any codes?
jj71787
Dec 30, 2014 02:15 PM
CARiD
Dec 26, 2014 04:20 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
NAVY99
Oct 3, 2002 03:47 PM
