car wont start no spark
Old Oct 7, 2008 | 04:36 PM
quickchek321's Avatar
i have no spark going to my plugs becuase i use a spark plug tester aslo i try the main wire going to the coil to see it spark still nothing im confuse. i had it starting before after the mods then i had to do a valve adjustment then once it shut off a big black cloud of smoke came from my front end of my engine. ( i went threw the wiring)
(mod 306 cam 1.52 pro mangun rocker arms pacesetter long tube stock injector pcm not tune
Old Oct 7, 2008 | 05:11 PM
Got power to the coil? Check fuses.
Old Oct 7, 2008 | 09:15 PM
Tex95Z's Avatar
Opti Pigtail?
but seriously how many threads are you gonna make about these problems? Like I told you last night.
Originally Posted by Tex95Z
First you really need to add a "signature" With your car info, year, mods stuff like that. It is really hard to understand your problem with everything jumbled together like that.
You should outline like this.
1. car not running.
2. What have you done
3. what are the symptoms
obviously you could outline it a bit differently but you get the idea. That will make it much easier to help you.
From the sound of it you have quite a few different issues.
Noenav
Mar 1, 2019 07:38 AM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
