car wont start HELP PLEASE
Old Mar 13, 2005 | 09:04 AM
  #16
meangrn94ta's Avatar
Re: car wont start HELP PLEASE
im like 99% sure that i have the neutral safety switch taken care of because i called a friend of mine that is GM tech and he also has a 95 and he told me over the phone which ones they were. that is where i got the idea to check for the ohms in the key and under the dash.
Old Mar 13, 2005 | 09:10 AM
  #17
ulakovic22's Avatar
I'm having an on going problem with my theft deterent relay in the glove box. My problem is only on hot starts tho. Everything works fine until I turn the key and all I here is the relay making noise or nothing at all. I've replaced the relay, but it still happens. Check your BCM and relays using the diagram Shoebox provided.
Anthony
Old Mar 13, 2005 | 09:15 AM
  #18
oh i just remembered something when i turn the key on to acc. and leave it on for a short period of time the ses light and check gauges lights stay on is that normal?
Old Mar 13, 2005 | 09:16 AM
  #19
ulakovic22 whatis the BCM
Old Mar 13, 2005 | 10:40 AM
  #20
ulakovic22's Avatar
BCM is the Body Control Module.
Old Mar 14, 2005 | 11:54 AM
  #21
well i have to confess that once i found out why the car wouldnt start i kicked my ownself in the A@@. when i bought the new starter it had 2 small post well of course i used the worng one. yea i know dumb, and the bad part about it is my wife was telling me hey maybe u hooked the starter up worng. since she knows just enough about cars to make it danerous but she was right and she is rubbing it in too. LMAO
Old Mar 14, 2005 | 01:14 PM
  #22
I guess now you don't have to worry about the BCM that you don't have, anyway.
Old Mar 14, 2005 | 01:26 PM
  #23
1stz28's Avatar
Originally Posted by meangrn94ta
when i bought the new starter it had 2 small posts but one of them had a yellow tag on it and it said something like if u only have one of the small posts use this. so if i were to hook it up bacwards (swap the small posts) would it start?
The second post...the one you apparently used...gives full battery voltage to the ignition on start up in some older cars. It is energized when the solenoid is activated to start the engine. After that the ignition uses an inline resisitor of some kind.
Old Mar 14, 2005 | 07:04 PM
  #24
ulakovic22's Avatar
Hmmm....obviously I didn't know that. Learn something new everyday. What year did they come into play?
Anthony
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
