Car won't start help
Old Apr 3, 2011 | 07:12 PM
dragginS10's Avatar
My security light had been on for a month and I just ignored it until today when my car would not start. I tried to bypass the VATS by putting together resistors using this method http://vats.likeabigdog.com/. Well the security light is now off but my car won't crank. The gauges on my dash light up and my fuel pump turns on but when I turn the key nothing happens. Anyone input?
Old Apr 4, 2011 | 06:34 PM
ptrgsny's Avatar
Re: Car won't start help
maybe check your resistance again. sometimes a little bit off will effect it. just my 2 cents
Old Apr 4, 2011 | 06:45 PM
Nickw059's Avatar
you sure its not the starter?? you can try jumping it too label it out...
Old Apr 4, 2011 | 07:27 PM
rngilliland's Avatar
If by nothing happens you mean it doesn't even turn over I would check the battery cable connections, clutch interlock switch located on the clutch pedal and the starter.
Old Apr 4, 2011 | 07:32 PM
dragginS10's Avatar
Yea the pellet on my key was 11.8k ohms and my resistors that I made only added to 11.564k ohms...maybe that is the problem
Old Apr 4, 2011 | 07:38 PM
dragginS10's Avatar
also would the VATS not allow my fuel pump to turn on? because mine is turning on
Old Apr 4, 2011 | 07:52 PM
dragginS10's Avatar
I don't think it is the battery cable connections b/c my dash lights up, and how do I go about checking the clutch interlock switch and starter?
Old Apr 4, 2011 | 08:07 PM
maybe2fast's Avatar
you need to check if the starter is getting good signal (when you turn the key) and has good power and ground.
Old Apr 4, 2011 | 09:54 PM
If it was starting and now the starter won't even turn the most likely cause, and easiest thing to check, is the battery connections. The fact that your dash lights work doesn't mean you have a good connection.
Old Apr 5, 2011 | 06:40 PM
94Z28LS1toLT1's Avatar
i agree because my car had the same issue it turns out it was a ground around the starter wire that had a broken terminal good luck
Old Apr 5, 2011 | 06:54 PM
There is a fairly wide tolerance on the resistor value. Look at Shoebox's guide:
http://shbox.com/1/4th_gen_tech2.html#pass_key
You are within the tolerance.
Pull the cables off the battery, and look for corrosion, both on the faces of the terminals/wires and inside the ends of the wire. Check the 12V cable at the starter.
Old Apr 5, 2011 | 08:14 PM
dragginS10's Avatar
thanks guys...ill be trying all of this tomorrow
Old Apr 8, 2011 | 11:58 AM
dragginS10's Avatar
didn't work.. have to bring it to a shop tomorrow
Old Apr 8, 2011 | 02:18 PM
SilverZConvertible's Avatar
Before you go to the shop check the ignition switch. Exact same thing happened to me. Pretty sure you can buy one and try and if thats not it return it. I've done that sort of thing a few times at Canadian Tire.
The ignition switch is way down on the steering column its not where you put your keys in. I think shbox has it on his site.
Old Apr 9, 2011 | 04:56 PM
dragginS10's Avatar
Turned out to be a bad starter...didn't think it would be since the starter was only 3 months old, but I'm lucky I got it tested before I took it to the mechanic.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
