Car wont start but cranks
Old Jun 9, 2008 | 07:54 PM
lt1stroker's Avatar
Ok so the saga continues. Car wont start but it cranks. i had a mechanic look it over and there telling me the problem is either my distributer, coil, and ignition. i have a msd ignition from summit but i dont know if can get an exchange. Any help would be appreciated
Old Jun 9, 2008 | 09:45 PM
Red93Camaro's Avatar
my car is doing the same thing.
Old Jun 9, 2008 | 10:14 PM
pcgamer4life's Avatar
Easy to narrow it down:
Check for spark, pull out a plug wire and see if you're getting spark when you crank it. If so, your problem is either fuel related, or somethings jacked up in the ignition system (crossed plugwires or bad opti). If you're getting spark at all, then it's not your coil or your ignition module. (I'm pretty sure... someone correct me if I'm wrong). No spark = replace coil and test ICM (autozone can do it). If you do that and still no luck, it's more than likely your opti. There are other options, like valves being out of adjustment or something, but it's probably electrical.
Old Jun 9, 2008 | 10:28 PM
lt1stroker's Avatar
^ Is it expensive to fix?
Old Jun 9, 2008 | 11:03 PM
Have you scanned it for codes?
Old Jun 9, 2008 | 11:41 PM
lt1stroker's Avatar
^ Codes? sorry i dont come by
Old Jun 9, 2008 | 11:55 PM
The PCM (computer) monitors the engine vital sensors and control devices, and sets "trouble" codes when things aren't working right. You can retrieve the codes from the PCM by attaching a "code reader" to the ALDL connector under the dash, by your right knee. Your 96 has an OBD-II PCM, so all you need is a cheap (<$50) OBD-II code reader to pull the codes out of the PCM.
When you get the codes, you look them up on Shoebox's code list. There's a "tab" for OBD-II Pxxxx format codes at the bottom of the page:
http://shbox.com/1/Dtcs.htm
Old Jun 10, 2008 | 12:01 AM
lt1stroker's Avatar
^ where can i get a reader? Would a mechanic have one?
Old Jun 10, 2008 | 05:22 AM
Many auto parts stores have them, and scan for free. But that's not going to help you if it won't start. Might be able to borrow one or rent one. A simple OBD-II code scanneer can cost less than $50. Harbor Freight sells them. More sophisticated scanners or software systems can cost upwards of $500. The GM technicians use the OTC Tech-2, over $2000.
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Lions3
Apr 11, 2003 10:55 AM
Dave19yz28
Jan 26, 2003 01:45 PM
