Car won't start again
Old Feb 24, 2003 | 01:09 PM
94blkTA's Avatar
Tried to start the car for its weekly drive and it wouldn't start, again. You can crank the car over as much as you want and doesn't seem like it's even firing. Then as soon as you let off the key it will start dieseling backwards. The car has been doing this every once in while for almost a year, it does it maybe once every couple months. 95% of the time the car runs fine, but then it does this.
I have tried about everything I can think of to fix this. Unhooked the accel ignition and re hook the stock, no help. Swaped out coils, no help. New fuel pump, does seem to have helped this problem. Swaped out the injectors for different ones, no help. Swaped out optis, didn't help. I've checked timing on the cam, it was good. Plugs are basicly new, so are the plug wires. Swaped out starters, no help. Any other ideas.
Old Feb 24, 2003 | 01:43 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
you either
A. need a new fuel filter
B. fuel fouled your plugs
Old Feb 24, 2003 | 01:48 PM
94blkTA's Avatar
Fuel filter was replaced about 1k miles ago. What exactly would cause it to diesel like it is, it'll do it for several seconds sometime.
Old Feb 24, 2003 | 01:56 PM
treyZ28's Avatar
the unGodly amount of gas in there being compressed maybe
replace those plugs
maybe even turn the motor without the plugs in there to get the gas out maybe
Old Feb 24, 2003 | 02:01 PM
94blkTA's Avatar
I've got an extra set of plugs laying around, i'll toss them in and see if they work better, we'll at least the seven i can get without taking one of the headers off. If the first seven help I'll go for the last on too, lol.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
