Car wont start...again
While I was charging my AC, I had an erratic idle after about 5 minutes of steady idle then stall. The car fired again with the same poor idle then died for good. I check shoboxes opti verification and i have 12 dcv on two terminals and 2 acv while cranking on another terminal. I checked spark on two plugs and i have a strong blue fire.
I checked the injector caps with a test light and i had light on one terminal and nothing on the other terminal, ever, while the car was cranking. I also checked the codes and the car threw a code 41 (electric spark timing is open). I also have 40 lbs on the fuel rail. I checked the fuses, and unplugged the MAF to see if the car would start. I am curious about the no signal to the injectors, just checking to see what you guys thought.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
