Car wont start after rebuild, please help.
Old Jul 11, 2005 | 08:28 PM
  #16
Silvershark's Avatar
Re: Car wont start after rebuild, please help.
Can someone do me a favor and try and ohm the two middle connections on the icm connector and ohm out the two outter two and tell me if they ohm out. I am trying to see if they are supposed to ohm out. Because I am getting continuity between the two outside two and the two inside two.
Also, are their any wires under the steering column that may cause the car not to get any spark that I can test?
Thanks.
Old Jul 11, 2005 | 08:32 PM
  #17
Also looking at my Haynes troubleshooting manual it says connector to the ICM is B5, where is this located on the engine? Is it connected to the pcm? And if so which wiring harness, Grey, Blue, Red, or Black?
Old Jul 12, 2005 | 01:42 AM
  #18
Please help. Someone must know where the connection to the ignition coil module is on the pcm side. I dont want to unhook all my wiring and have to trace down the 4 wires that go to the ICM by cutting open the wire loom if I dont have to.
Old Jul 12, 2005 | 06:27 AM
  #19
ZMAN Z28's Avatar
Shoebox's site has a wiring diagram that has a detailed schematic of the pcm wire in it. Do a search for his site.
Old Jul 12, 2005 | 01:55 PM
  #20
Ok, using shoebox's site I was able to trace down this far and I have found out that everything tests good. Everything in Red is good. I have ohmed them out and or followed the haynes manual on how to check to make sure it is functioning properly. The only thing left is to check the B connector that goes from the ignition from the pcm to the ignition module and make sure it is getting the 1-4vAC. If It is, then the ICM is bad?
www.akgaming.com/~kendall/images/wiring.jpg
Old Jul 12, 2005 | 04:22 PM
  #21
I went down to my local parts store and tested my old coil against a new coil and everything checked out fine. So the coil is defiantly good, the optispark is new, the optispark harness is new, the battery is new, the starter turns over fine, the alternator is a year old, only thing left is either the pcm or the ignition coil module?
I was able to upload via tunercat though, so I believe the pcm is fine....
Any ideas?
Old Jul 12, 2005 | 05:18 PM
  #22
1racerdude's Avatar
[QUOTE=Silvershark]I went down to my local parts store and tested my old coil against a new coil and everything checked out fine. So the coil is defiantly good, the optispark is new, the optispark harness is new, the battery is new, the starter turns over fine, the alternator is a year old, only thing left is either the pcm or the ignition coil module?
If battery is week it probably won't turn fast enough to start.
Is the opti installed correctly?
Old Jul 12, 2005 | 06:03 PM
  #23
ZMAN Z28's Avatar
Sorry I didn't re read all the posts. Are you also sure your fuel system is up to par?
ZMAN
Old Jul 12, 2005 | 06:33 PM
  #24
Yes fuel system is defiantly up to par. I think I may have found my problem... FINALLY!!
I opened up my knee bolster and I found this...
www.akgaming.com/~kendall/images/Alarm.jpg
www.akgaming.com/~kendall/images/Alarm1.jpg
It looks as though I have a python 1000 alarm system, if you look at the second picture there isnt a wire hooked up. I dont know if that is supposed to be hooked up or not.
I also removed my battery during my engine swap. I have heard of ignition cut out thats built into alarms... I wonder if that is what my problem is.
I am googling this python trying to figure out how to enable the stupid thing. I have a two button clicker on my keychain. The left one open and closes the door locks and the one on the right stops some time bomb ticking noise... ?
Old Jul 13, 2005 | 01:04 AM
  #25
Ok, I am half way done with the removal of the security system. Hopefully after it is removed the car will start like normal.
Nothing worse than a cheap security system.
Old Aug 1, 2005 | 12:49 AM
  #26
Black1995Z's Avatar
well, what happend? Did it start?
Old May 24, 2010 | 10:37 PM
  #27
charlymaine's Avatar
i had a wire from an alarm system spliced into the wire that went from the icm to the coil and it was broken. it wasnt very far up the harness to find and repair and it started right up after that.
Noenav
Mar 1, 2019 07:38 AM
Not Dave
Dec 11, 2014 06:32 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
