car wont start after radiator install..
Old Apr 23, 2003 | 06:10 PM
blak96SS's Avatar
I just got done finishing up putting in a new radiator and now the car won't start...It turns over fine, but then it dies...I havent driven it in about 3 days while I have been working on this. Any ideas??
Old Apr 23, 2003 | 08:56 PM
stlws6's Avatar
is it getting a spark and what do you mean it dies right after you start it it turns over and starts or does it just crank over
Old Apr 23, 2003 | 09:03 PM
Did you forget to plug a sensor in?
Old Apr 23, 2003 | 09:47 PM
philcam01's Avatar
The low water sensor if it's not plug in that'll do it. belive it or it happened to me
Old Apr 24, 2003 | 02:19 AM
blak96SS's Avatar
thanks for the responses, guys. The car will start, but it dies after about a second or two. The best way I can think to describe it would be that it can't hold an idle. Im pretty sure I plugged everything back in...Hopefully I just didnt get the sensor all the way in or something. I'll have to look at it tomorrow.
Any chance that it could be the opti? I sure hope not...
Old Apr 24, 2003 | 02:43 AM
Javier97Z28's Avatar
Moderator
did you spill coolant on the opti? that'd be kinda hard to do since you have to drain the radiator by the valve on the bottom, but uh, i guess it's possible..
Old Apr 24, 2003 | 08:18 AM
stlws6's Avatar
can you keep it going by keeping your foot in it. if you can and the motor jumps around alot you might have a miss because you spilled on the opti or disconnected a spark plug or coil alos check if she shooting any codes
Old Apr 24, 2003 | 09:10 AM
White Z 4 Show's Avatar
pull the wire off on the coil and take a wire brush, clean off the white corrosion. then put the wire back on. I noticed when I changed my coil the other day my wire wasn't all the way on and it idles a little low. I bet you could have hit it a few times taking the radiator out. Very easy to do....
Old Apr 25, 2003 | 02:14 AM
Laymaster's Avatar
if it won't hold an idle, perhaps you didnt' plug in your MAF sensor, or some sensor around there. I did that once (wasn't doing my radiator though)...
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
Dave19yz28
Jan 26, 2003 01:45 PM
