Car won't start after LT install
Old Jul 23, 2005 | 09:06 PM
raxxus's Avatar
Hey guys,
Just installed my pacesetter lts. Now the car won't start! I installed new plugs when I did it. ( ac delcos, gapped a .050 ) It's getting fuel, I took off the fuel rail to get a happy hooker on it, so I turned key to the on position a couple times to prime it. Fuel comes of out the shradder vavle now. I pulled off a wire, and put one of the plugs I pulled out in it and when I crank the engine, it doesn't spark! I had it against the header, in case it needed grounded. I just had the whole ignition system replaced at my shop ( cap, opti, ignition module, the works ) and it ran PERFECT when I parked it. Sadly, it took a month to install the headers b/c the engine slipped off the jack and fell 1" on the drivers side, taking off part of one finger of mine. What do you guys thing is going on? I pulled the wires to the air pump, it makes a noise when I turn it to the on position. ( headers have two bolts in them to block it ). So I thought maybe it was just a vacuum leak, so I put two of the tubes on the air pipes, and capped them, to no avail.
Thanks for the help!
mark
Old Jul 23, 2005 | 09:11 PM
My Iroc Z28's Avatar
Re: Car won't start after LT install
best advice i can give is to go back over everything that you may have disconnected and make sure it's connected...
Sorry to hear about your finger.
Noenav
Mar 1, 2019 07:38 AM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Snake Slayer
Jul 29, 2002 12:39 PM
