Car won't start
Old May 4, 2006 | 09:27 AM
jasonwinn's Avatar
Car won't start
Ugh went to start my car this morning, put the key in, and all my intertior,exterior lights and my cd-deck work no problem. I turned the key to start and all the lights flicker and I just hear a sound like something is grinding. ANd car wont start >.< So I charged the battery to full, went to start, and it does the exact same thing. Its weird that all my lighting works fine, headlights and radio and stuff but it just wont start up
The battery is only a month old. Its a 96 z28 with 143k on it.
I didnt get a chance to check for error codes cause I had to use another car to get to work, but was wondering when I get home where should I look first for problems?
Thanks!
Old May 4, 2006 | 09:38 AM
camaro1fastz28's Avatar
Re: Car won't start
mabe starter
Old May 4, 2006 | 09:51 AM
OBE1 95Z28's Avatar
Re: Car won't start
Check the connections to the battery are clean and tight; also verify the ground cable to the engine block and positive cable to the starter and clean and tight.
Old May 4, 2006 | 09:56 AM
jasonwinn's Avatar
Re: Car won't start
I double checked those when I was fiddling with stuff this morning. It is probably most likely the starter, cause its like a grinding sound when I go to start it, not like a typical "chk chk chk chk" sound.
If hook up a OBDII reader, will the starter throw an error code?
Old May 4, 2006 | 10:00 AM
93formula350's Avatar
Re: Car won't start
if the starter is the issue i dont think it will throw a code. this sounds like a very similar problem i was having with my car... i would go to start have full power, then when it went to crank all i heard was a clicking/grinding sound coming from the passanger floor area... turned out my starter was totally fried, so i replaced the entire thing, solenoid and all... fixed it... try giving power straight to the starter itself and if its grinds you will know that its the starter giving you the issue...
hope this info helps. good luck
Old May 4, 2006 | 10:01 AM
jasonwinn's Avatar
Re: Car won't start
Thanks everyone I appreciate all the help!
I will see what I can do once im off work and get back to you all
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
