car wont start
Old Jun 13, 2004 | 04:32 PM
97_lt1_MG's Avatar
car wont start
Has this happened to anyone: i have a 97 z 6spd, took it to 5800 rpms shifted to second and when i released the clutch my car died and no i cant get it start again, ive checked all the fuses, unhooked the battery to reset the ecu but all it will do is crank but wont turnover, would apreciate some help.
Old Jun 13, 2004 | 05:02 PM
Larry95Z28's Avatar
You might have broke your timimng chain. I would take off a valve cover and see if the rockers are moving.
Old Jun 14, 2004 | 01:51 PM
kamba93lt1's Avatar
Fuel pump would be another suggestion.
Old Jun 14, 2004 | 10:20 PM
97_lt1_MG's Avatar
i took valve cover off and the rockers do move when i crank it, also i pulled the coil wire of the distributor to check for spark and there wasnt a spark, would that mean the coil is bad or maybe the coil module?
Old Jun 14, 2004 | 10:34 PM
my94blackz's Avatar
Coil should be replaced asap. but i would also check all connetions.
Old Jun 14, 2004 | 10:47 PM
HBHRacing's Avatar
give this a shot
http://mainstreamtopics.com/forum/in...p?showtopic=78
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
