Car wont shift
Car wont shift
Heres the story, I have a 383 with the 4l60e, well the engine work and trans worked great except it had a small leak at the rear main, so we pulled the engine, and just got it all back in, start it up, and put it in gear, and NOTHING. Any suggestions on what I couldve done wrong. Thanks Paul
will it drive in first?? and just not shift???
adjust the TV cable at the throttle body
tighten or loosen the cable little by little and take it for a test drive
when i say little by little i mean a 1/4 of an inch is a lot!!
i just had to do this on my friends mustang and the cable adjustments are setup the same way
since its the same tranny you should be able to adfjust it at the TB instead of having to crawl under the car for major adjustments
hope that helps
hope that helps
All i did was unbolt it from the flywheel then bolt the trans and engine together, i never moved the converter. Is there anyway i can tell if the converter is not seated right, and then seat it with the trans in the car at all, or am i screwed. Thanks for you help Paul.
Does reverse work? Does putting it in 1 work? put the car in drive and make sure the driveshaft isn't turning (could always be the rear end but unlikely considering the circumstances that the trans stopped working under). If it just won't move then I'd say its time to take it to a trans shop and have them inspect it. Good luck.
Why don't you just take it back to the trans shop that built the trans. With only 200 miles on the clock I'm sure its under warranty and they won't have a problem checking it out. Good luck and let us know how it turns out.
When you tightened the nut that holds on the shift lever did you hold the lever in place (with pliers or something) or just tighten it down. You could have broke something if you were not holding the lever. You don't want to tighten against the internal linkage.
BTW I'm sure you know this but the 4l60e does not have a TV cable. The 4l60 (not e) from a 93 has one
NewsBot
Dec 3, 2014 12:30 PM
