Drivetrain weakness?
Old Dec 21, 2003 | 02:42 PM
Briank8811's Avatar
Where will my weaknesses be considering im running a 400-450 HP at the crank thru an otherwise stock Drivetrain?
Old Dec 21, 2003 | 02:45 PM
ibanez6rg's Avatar
Torque arm, robs power anyways. Rear-end gears, axles... Look into getting a 12 bolt.
Old Dec 21, 2003 | 03:00 PM
Briank8811's Avatar
Well if im not looking to do very hard launches and am generally not going to be letting the clutch normally drop at anything above 3500 RPM, then do i need to worry about anything?
Old Dec 21, 2003 | 04:32 PM
Briank8811's Avatar
ANY COMMENTS?
Old Dec 21, 2003 | 04:40 PM
whitedakota's Avatar
Arrow
well as a matter of fact i just had 3.42's installed about a month ago and i have about no where near 400hp...but mines a VERY strong A-4 car...anyways i broke 2 teeth of the pinion gear, and about 9 of the ring gear teeth were looking in very very bad shape...
i have been racing on concret roads with about 12psi and it hooks extremy hard, and my car usually turns sideways on any other surface...i had two of my buddies with me and we pulled up to a stop sign torqued it to about 2400rpm then took off it pulled real hard then when it shifted into 2nd it went "POP!"...so we had to trailer it 30 miles back to the shop, and install my old 2.73's (man those things suck)
so in my opinion id strengthen the rear end first.
steve...
p.s...this happend last night about 9:30
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
WobblySausage
Oct 7, 2015 02:44 PM
War Engine
Aug 21, 2015 05:28 AM
alphaauto
Jul 26, 2015 04:40 PM
