Car will not run.
Listed below are the sensors that are known to work with the painless harness. some of these sensors ans switches are gm part numbers and some are ac delco part numbers.
This list came straight from the painless manual for the harnes, and i have confirmed that the haness will only work with these partnumbers listed. I confirmed this over the phone while speaking to a painless rep.
Ecm service number 16188051
brake switch gm # 25524845
IAT Gm # 12110319
ICM Ac Delco # D-1986-A
Fuel pump relay Gm # 14089936 or Ac delco # 15-8240
Coolent temp sensor Gm# 25036979
Ignition coil Ac Delco # D-573
O2 sensors Gm# 25312184 or Ac Delco # AFS 75
TPS sensor Gm # 17106680
Egr solenoid Ac Delco # 214-396
Gear indicator switch Gm # 15705308 or Ac Delco # D-2286A
MAP sensor Gm # 16137039
IAC sensor Gm # 17113099
Knock sensor Ac Delco # 213-96
Air pump relay Gm # 14100455 or Ac Delco # 15-8426
Air pump Ac Delco # 2604-4885
MAF sensor Ac Delco # 213-252
Canister purge solonoide Gm # 1997201 or Ac Delco # 214-565
Componets with partnumbers other than listed may plug into Painless harness numbers 60502 and /or 60505, but the part numbers must match the list above for proper opperation.
IAT Gm # 12110319
Also, if I were to buy all of these sensors, I could'nt use a different brand at all? Even if they can cross the part numbers?? If so that is ghey and Painless deserves a kick in the crothal region.
when i talked to painless they said that it had to be these sensors only. they are some *******s too. so you did have it hooked up my way with the factory harness. ok give me a few min and im going to go back over this post and do some trouble shooting for you.
Alright. It may take a while. The next day I have to work on it will be next Wednesday. I'll check my plugs to make sure they all have good spark, and check my grounds.
Yeah, I actually wired it up using the "LT1 wiring for dummies" on thirdgen.org, I cant seem to find it now, it must have been deleted, but from what I saw it was almost exaclty the same as yours. Except they didnt have the wiring for the ALDL port. I'll check it out Wednesday and get back to you. Thank you for your help.
There write up was confusing and did leave a few things out. I just checked and all the pages work except page 1 where the write up is. I think mines a little easier to follow and it has all the info listed on it for you to doubble check if your not sure about something. makes thing alot easier than having to run in the house and search for pinouts and stuff like that.
