In car wideband, any of them good?
Old Aug 5, 2003 | 01:28 AM
neat's Avatar
Summit sells an in car wideband that uses an O2 style sensor for about $200. Is it accurate at all? I had an autometer gauge in my TA that tapped into the stock O2 signal and I hated it. The light just bounced all over. Are any of them any good?
Old Aug 5, 2003 | 11:55 AM
Give us the part # from Summit. I did a search on "O2 meter" and all I got was an Accel A/F meter for $233 without the sensor and $268 with the sensor. Not likely that's a "wideband".
Typical wideband sensor is in the $250-350 range, plus enough electronics required to bring the typical cost to about $1,000. If you have found a "wideband" for $200, I'm sure a lot of people would like to know more about it.
Old Aug 6, 2003 | 12:44 AM
neat's Avatar
Here ya go
http://www.ufba.org/forum/index.php?...;threadid=4244
I can't figure out how to post the pic, so here ya go.
Old Aug 6, 2003 | 10:27 AM
sssalah's Avatar
This is not a wide band, it uses your exesting sensor to flash some lights. you can get a similar gauge from Autometer which does the same, indicate rich or lean.
A wide band will give you an axact number of your air/fuel ratio and uses a special 5 volts linear sensor.
Old Aug 6, 2003 | 10:56 AM
neat's Avatar
That's what I had before, no good. Thanks.
Old Aug 6, 2003 | 01:48 PM
You might want to do a "search". There is a kit available that sort of goes 1/2-way to being a wideband sensor. I think it uses a particular sensor out of one of the Japanese lean burn engines. I think you can build the kit and get the sensor for maybe $300.... can't remember. Look on the "Computer Programming...." board.
Old Aug 6, 2003 | 04:07 PM
KenP's Avatar
Look here http://www.diy-wb.com/info.htm for the DIY'er.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
