Car warms up, then low idle and oil pressure after driving??
Old Jun 4, 2005 | 10:17 PM
camz383's Avatar
I took the ole Z out for a spin to a car cruise tonight and well i drove it about 10miles to the cruise and then I get to a stop sign where it starts idling really low and loses oil pressure. Im assuming the low oil pressure is just because im losing idle, it seems like it might cut out if i let it go down, it gets around 500rpm.
This used to happen when i was at the track and after id run it and let off to pull in to get my time slip, it would get down around 500 and then id have to give it some gas before it cut out on me. After that, I changed the O2 sensors last season and it started to get better, but now its back to the same thing. I did put about 2 gallons of race gas in it last season once, that wouldnt have made them go bad would it?
Anyone have any ideas?
Old Jun 4, 2005 | 10:38 PM
Z95m6's Avatar
Re: Car warms up, then low idle and oil pressure after driving??
i imagine it has something to do with your IAC most people have idle problems with larger cams. If you are running a stock TB you can drill out the hole in between the throttle blades if you are running an aftermarket tb its a little harder.
Old Jun 4, 2005 | 10:49 PM
camz383's Avatar
ive got a decent cam and just put a new 58mm holley tb on it, could this have something to do with it?
Old Jun 4, 2005 | 10:54 PM
Z95m6's Avatar
i'd bet so. Do you have any sort of scanning tool. I'd bet your IAC counts are maxed out at 160. The easiest way to get it lowered is to drill a hole in your rubber intake elbow and install a vaccum fitting in it. Then run a rubber hose from that fitting to a vaccum port on the intake. It'll help lower your IAC and it won't create a vaccum leak. My BBk 58mm TB doesn't really allow you to modify the TB to allow more air at idle.
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
