Seaform???
Old May 25, 2005 | 09:27 PM
lookingforwheels's Avatar
Seaform???
Hey guys whats up, I just put a can of seafoam in my tank thinking it would clear things up. But now my car seems to run worse? Do you think the fuel filter is clogged now or something? Any ideas.
Old May 25, 2005 | 10:29 PM
magnumv8's Avatar
Re: Seaform???
you may have loosened some junk up in the tank which clogged the fuel filter.
Old May 26, 2005 | 05:44 PM
fredmr39's Avatar
Re: Seaform???
You said the car 'seems' to run worse - in what way? Lack of power? Does something sound different?
Old May 26, 2005 | 08:09 PM
Re: Seaform???
It stumbles a little bit more when im not giving it gas. I just put a fresh tank of gas in so I'll see how it feels. It feels like the car needs some injector cleaner if that makes sense.
Old May 26, 2005 | 09:13 PM
pHEnomIC's Avatar
Re: Seaform???
seafoam is an injector cleaner, supposed to be one of the best, comparable to techron. I would just fill up on premium, should solve all problems.
Old May 26, 2005 | 09:58 PM
1996camarors's Avatar
Re: Seaform???
The problem with seafoam is when you use it, it takes all the junk and puts it right into your filter. Just with the deep creep it puts all that carbon on your spark plugs, o2 sensors, engine oil
So be careful
Old May 26, 2005 | 11:17 PM
Re: Seaform???
1996camarors The problem with seafoam is when you use it, it takes all the junk and puts it right into your filter. Just with the deep creep it puts all that carbon on your spark plugs, o2 sensors, engine oil
So be careful
Off-Topic:
Why was removing your cat the worst thing you ever did?
Old May 26, 2005 | 11:20 PM
Exclamation Re: Seaform???
Originally Posted by lookingforwheels
Off-Topic:
lol have you ever heard a v6 with a gutted cat
it sounds like poo-poo
Old May 26, 2005 | 11:34 PM
WeirdRich's Avatar
Re: Seaform???
what exactly does poo-poo sound like? lol
and dont say a V6 with a gutted cat
Old May 26, 2005 | 11:53 PM
Re: Seaform???
LIKE this
600rpm: rumble rumble rumble sounds cammed
1000rpm rumble mmmmm rumble mmm
3000rpm berrrrr berrrrrrrr berrrrr
4000rpm raaaaaaaaaa raaaa ( sounds like a banshee )
5000rpm just sounds like air blowing lol( or is that the turbo??
Old May 27, 2005 | 12:15 AM
1996z28m6's Avatar
Re: Seaform???
ive noticed that most v6s with aftermarket exhaust anything usually sound like crap...i guess thats because im used to the v8 rumble
Old May 27, 2005 | 12:25 AM
Re: Seaform???
572 with LT's
I wonder how that would sound
Old May 27, 2005 | 11:21 AM
Re: Seaform???
Oh, I didn't realize you had a v6, I used to have a v6 with magnaflows, and with the cat installed it sounded okay, but I can imagine what it would sound like with no cat............
Old Jun 4, 2005 | 11:24 PM
blind527's Avatar
Re: Seaform???
What fuel filter and PCV valve *from autozone part numbers would be great* are for a 97 Formula?
For the PCV valve I pulled up PCV107
and for the fuel filter I pulled up FF508
I went to Shoebox's website and did a parts search, copied his part no.'s into the autozone search and pulled up these parts, are they any good?
Old Jun 5, 2005 | 12:44 AM
Re: Seaform???
You might want to make a new post with your question, the right people might not read this.
