Car troubles
Old Apr 8, 2004 | 11:00 AM
5.0eater's Avatar
Car troubles
Well my car is having some issues. Whenever i get on it at about 4500 rpms the battery gauge starts looseing volts bad, then this causes the car to start popping and wont shift until let off of it. My air pump is going bad could this be part of my problem thanks for any help guys.
Old Apr 9, 2004 | 12:46 AM
5.0eater's Avatar
Old Apr 9, 2004 | 07:30 AM
HBHRacing's Avatar
te first place to start is a charging system test. Autozone can do it for you. I would also check to make sure that the belt is good, tight, the tenioner is strong, and there is nothing on the belt that will let it slip IE power steerin fliud or weep hole driping coolant
Old Apr 9, 2004 | 04:37 PM
pearlpurple's Avatar
check battery connections, grounds, alternator charging, battery life, coil,
that is where I would start
Old Apr 10, 2004 | 01:11 AM
5.0eater's Avatar
altenator is fine got it checked 2day and connections were all good
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
slothgrant
Aug 22, 2002 03:01 PM
squirrels
Jul 13, 2002 01:58 AM
