Car trouble starting! HELP!
Old Aug 26, 2008 | 01:36 PM
lt1stroker's Avatar
I know this probably has been covered, but i couldnt find any threads that directly cover my problem. Ok so about a month ago my car would fire up right away, doesnt matter if its 6am or 3pm at 100 degrees. Now my car barley starts up and i have to crank it twice and add gas to start it up. I dont know if its my fuel pump or my battery.I dont know how to find the fuel pressure but Please help.
Old Aug 26, 2008 | 01:53 PM
BUBBA's Avatar
More information: Does it crank good and just not start? Does it crank slowly or barely turn over? If it cranks slowly or not at all it would be a battery problem---too little juice. If that is the case, you probaly need a new battery, especially if your present one is any wheres near the warrant expiration. If your fuel pump is going, you might want to check the fuel pressure by hooking a fuel pressure gauge to the schrader valve which is located on the pass side near the firewall----it has a little screw on cap over the actual valve which works like a tire valve, i.e, it opens when it is depressed. Get a regular gauge with a hose, but make sure the end of the hose will fit easily up under the cowling a attach to the schrader valve. Visit your local shop and have them choose the right fitting. The std. pressure should read around 43-35 psi with the vavuum hose (on the regulator unhooked) and around 8 less with the vacuum line attached.
If it is not a battery problem or a fuel problem, perhaps your plugs may be in need of changing (fouled or worn). Also as far as fuel, you might want to change your fuel filter as a prevention measure. Also make sure that your air filter is clean. If you have more information, let us know. JMHO
Old Aug 26, 2008 | 05:09 PM
lt1stroker's Avatar
hey thanks for the info! Appreciate it. Now the car doesnt even start, it makes clicking noises when i turn the key. the oil pressure goes up after i crank it a couple of times. It use to crank but not so much anymore. Also, the schrader valve is located on the rear right of the intake manifold right? Also, where can i get a fuel filter? Im going to get a new FPR from autozone too.
Noenav
Mar 1, 2019 07:38 AM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
slothgrant
Aug 22, 2002 03:01 PM
