Car throwing yet another code...please help
Old Sep 20, 2003 | 09:37 AM
StephenF04's Avatar
The code is: Random Cylinder Misfire. Lately I have thought my clutch is going bad. The way it seemed to slip up hills and under load. However the problem is getting worse and it might not be the clutch. The car misses and bucks very bad. Sometimes worse than others. The guy at Advance suggest I try plug wires first, then distributor if the wires don't fix the problem. Anyway just wanted to see what you guys thought.
THANKS
Stephen
Old Sep 20, 2003 | 10:40 PM
StephenF04's Avatar
anyone have any thoughts??
Old Sep 21, 2003 | 01:07 AM
-coil wire (check for corrosion)
-plugs
-plug wires (check Opti terminals for corrosion as well)
-coil
-ICModule
-Optispark distributor (check harness connections for corrosion)
-leaking EGR valve
-dirty injectors
-dirty fuel filter
-failing fuel pump
Old Sep 21, 2003 | 09:10 AM
StephenF04's Avatar
-plugs
-coil
-ICModule
-leaking EGR valve
-dirty injectors
-dirty fuel filter
-failing fuel pump
Thanks man. I'll start trying some of these things.
Old Sep 22, 2003 | 10:49 AM
StephenF04's Avatar
Wanted to also add I notice that the bucking and missing seems to happen when the car gets warmed up a bit. When I first start and drive it seems to be ok. Once you drive for a few minutes the problem picks up. Hope that can help y'all narrow it down some.
Old Sep 22, 2003 | 10:55 AM
The fact that it gets worse when the engine warms up could be related to:
1) components that are subject to heat soak and breakdown:
-wire insulation
-ICModule (a real problem with heat due to location on head)
-Opti optical module
2) the changeover from open loop to closed loop.
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
