Car still tuggs or pulls at low throttle...
Old May 19, 2003 | 04:43 PM
96z's Avatar
96z
I was having a problem with the car pulling or tugging at low RPM's and low throttle. I had a TPS code but that went away with a new TPS. The car isnt tuned totally yet and is still rich. It almost feels like a miss so Im going to change the plugs...but only happens when mentioned above?
Is this cam surge? fouled plugs? too much fuel?
Its not so much a problem as much as it is annoying....
Old May 19, 2003 | 08:10 PM
96z's Avatar
96z
Could anyone take a guess?
Old May 19, 2003 | 08:14 PM
Rodrigues's Avatar
I already gave my opinion in my other thread and still think that it is cam surge. It will only go away with a really good tune. I have PCM4Less and still have cam surge. Under 2k and no throttle you will probably have jerks/tugs and gets progressively worse until you add throttle, am i correct?
Old May 19, 2003 | 08:24 PM
96z's Avatar
96z
Your right on...I was hoping for a quick fix. Thanks
Old May 19, 2003 | 11:43 PM
quickSS's Avatar
I was told that cam surge is technically called, "The Hot Rod Massage"
Karl Ellwein
Old May 19, 2003 | 11:57 PM
96speed's Avatar
Hey Matt...Sounds like cam surge to me. I'm getting a bit of it below 1500 in 1-3.
If I try to idle through a parking lot it gets SERIOUSLY "jumpy."
Ryan
Old May 20, 2003 | 01:47 AM
96z's Avatar
96z
So how do you tune this out? Anyone know?
Ryan mine is only when barely on the gas in 1-3, at idle its there but not as noticable.
Old May 20, 2003 | 01:54 AM
96speed's Avatar
Matt...I bet the extra cubes and increased compression helps yours out a little. I was under the assumption that by manipulating the timing you couldget rid of it. However, I know NOTHING about tuning .
Let me know if you find a fix, although its not that bad for me - I don't expect it to drive like stock .
Ryan
Old May 20, 2003 | 10:35 AM
96z's Avatar
96z
Ryan true, they cant drive as nice as they used too.
Hopefully timing will be able to take care of it...
cmdeshon
Dec 12, 2014 10:51 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
