Car still running like crap
Old Mar 6, 2007 | 06:32 PM
AXEMAN's Avatar
It is still throwing a DTC 42. I spliced in a couple of new pieces of wire at the ICM connector and the PCM and it still gives this code after it runs a little while. So then I just changed the whole wire and it still came back. Do I change the connector at the ICM next? I am at my wits end any help would surely be appreciated.
PS yes I have datamaster so I have reset my pcm each time after I work on it.
Old Mar 7, 2007 | 04:04 AM
throb's Avatar
DTC 42 is only supposed to set during cranking and if detected, the PCM will disable the injectors to prevent flooding. Possible causes for it are faulty ICM and/or wiring, open or grounded circuit somewhere or a faulty PCM.
If it's setting after it's been running like you say, perhaps the PCM is toast?
Old Mar 7, 2007 | 07:09 PM
AXEMAN's Avatar
Yea I have read that also but it will run fine for a while and then the injectors start to cycle. My pcm is only about a year old from the dealer but I do have another one to replace it with. I had the icm checked already. I'll let you know if changing the pcm works. Thanks.
Old Mar 10, 2007 | 02:30 PM
AXEMAN's Avatar
OK, so I replaced the pcm and then I drove it around. It ran real strong at first but then it started missing at about 1500 rpm's all the way up to wot. It started after it got warmed up but it never threw a code. I had datamaster hooked up and recording the whole time. I had my ICM checked (said it was good) and I have changed everything else so what do you guys think about a new ICM and a new pigtail for it? Maybe it gets hot and acts up. BTW I have done the washer mod to move it away from the block. Thanks
Old Mar 10, 2007 | 02:48 PM
Guest47904's Avatar
Guest
Mavbe it's actually a A/F ratio problem after it goes into closed loop. Try disconnecting an O2 and see if it runs better once it warms up.
Old Mar 10, 2007 | 03:09 PM
AXEMAN's Avatar
The o2's are brand new too. It ran in closed loop for maybe 10-15 minutes before this started.
Old Mar 11, 2007 | 06:37 PM
AXEMAN's Avatar
Anybody got any ideas
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
