rocker arms
Old Mar 10, 2007 | 11:10 PM
reamo04's Avatar
rocker arms
couple questions
what size is the stock stud? 7/16, or 3/8?
will i need a computer tune running a higher-ratio of rocker arms since it will be increasing lift?
Old Mar 10, 2007 | 11:34 PM
Z95m6's Avatar
Originally Posted by reamo04
couple questions
The stock size is 3/8". You don't need a tune for roller rockers but you do need better springs.
Old Mar 11, 2007 | 01:59 AM
jclark311's Avatar
The stud that goes in the head is 7/16, the stud the rocker sits on is 3/8 stock.
Old Mar 11, 2007 | 08:17 AM
Z-RATED94's Avatar
Exactly, but if you have not bought the the rockers yet, go with the 7/16 studs and buy the 7/16 rockers. That way the studs will be more stable if you ever cam it. The Hotcam springs will be ok for now and their cheap. That should get you at least 10 or so HP. Then have one of our supporting tuners hook you up with a mail order tune and pick up another 10-15 more HP.
Old Mar 11, 2007 | 04:05 PM
reamo04's Avatar
do u guys have any recommendations on the rockerss?
i just want to get maybe a little more lope out of my cam, maybe a little more power. Its a stock cam, so maybe i could go with 1.7s and be alright for now until i get a 383 done.
if i do 1.6s, i was thinking maybe some crane gold roller rockers?
if i do 1.7s...idk
Old Mar 11, 2007 | 04:09 PM
Z95m6's Avatar
if i do 1.7s...idk
Comp Pro Mags.
Old Mar 11, 2007 | 04:46 PM
reamo04's Avatar
what are the specs of the 7/16 studs i want?
Old Mar 11, 2007 | 06:11 PM
2000GTP's Avatar
If you plan to do a cam upgrade down the road, I would go with 1.6 ratio NSA rockers. Comp Pro-Mags would be my choice as well.
Old Mar 11, 2007 | 06:31 PM
reamo04's Avatar
yeah, im gonna do the 1.6 pro-mags for a 7/16 stud. To upgrade the stud, what do i need? I found new studs on summit, but theres something like 7/16
x20-inch, so, what are the specs of what i need?
Old Mar 11, 2007 | 06:43 PM
2000GTP's Avatar
I believe that is the part number you'll need from Summit. CCA-4501-16 ThunderRacing sells them for almost 10 bucks cheaper.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
