Car still not driveable after heads/cam
Old Apr 7, 2004 | 08:35 AM
  #16
2002LS1Z28's Avatar
With that heads/cam set-up, your car needs a 3000+ stall a LOT more than it needs some 3.73 gears right now. The stall will do much more for your performance as well as help out with some of your drivability issues.
Then later add the gears to compliment your torque converter...
Mike
Old Apr 7, 2004 | 01:34 PM
  #17
ibanez6rg's Avatar
The Scanmaster is giving me codes 16 - OptiSpark low resolution pulse not found and code 48 - MAF sensor circuit.
Old Apr 7, 2004 | 08:18 PM
  #18
ibanez6rg's Avatar
ttt
Old Apr 8, 2004 | 08:16 AM
  #19
ClawSS's Avatar
Make sure your MAF is plugged in....but I also think that bunker is on track with the IAC counts and table adj.
If you do not have a laptop with datamaster or freescan...buddy up with someone who does. This can tell you BUNCHES of things that you may never have known.
Old Apr 8, 2004 | 08:55 AM
  #20
mineralwater's Avatar
When I installed my cam, I didn't line up the 12 'o clock and 6 'o clock dots on the timing gears right - it was skewed/retarded by 1 tooth.
Sucks that I had to tear it back down all over again but once I got that fixed, the car drove like a dream. Before that, the car was choking and sputtering under load, although it idled fine and sounded like one chunky *** cam (even for a hotcam).
Just something to check when you're all out of ideas, I guess. Good luck!
Old Apr 8, 2004 | 11:07 AM
  #21
ibanez6rg's Avatar
We double checked it so I think the timing is fine... Well, atleast I really hope so! I've also heard problems about IAC counts and what not and having to drill out the hole a little bigger.
But I'm also thinking if there's a MAF sensor circuit problem, that would cause horrible driveability.
I'll see what I can do about Datamaster or Freescan.
Old Apr 8, 2004 | 11:25 AM
  #22
xxsaint69x's Avatar
yeah, make sure your MAF is working..if its not, your car will not run good at all using the VE tables.
Old Apr 8, 2004 | 10:48 PM
  #23
ibanez6rg's Avatar
I'll go sneak the MAF off of Dad's Vette tomorrow and see what happens... shhh.
Old Apr 8, 2004 | 10:52 PM
  #24
Spinner's Avatar
Just unplug yours.
Old Apr 8, 2004 | 11:00 PM
  #25
ibanez6rg's Avatar
Originally posted by Spinner
Just unplug yours.
I'll try that. Why?
Old Apr 9, 2004 | 10:55 PM
  #26
Quick96Z's Avatar
By the way man, i am in the same boat you are....230/236 cam and ported head swap. I have a tune from PCM4less, but i still have the exact same problems u are having. Idles at 900RPM just fine, but wont drive for crap. I hope it's just crossed wires.
good luck to us,
trav
Old Apr 9, 2004 | 11:01 PM
  #27
Spinner's Avatar
I'll try that. Why?
Because it will ignore MAF readings and run in Speed Density mode (think 1993 cars). If it's a MAF problem, then it should run better with it unplugged, and you'll know you need a new MAF
Old Apr 9, 2004 | 11:16 PM
  #28
Quick96Z's Avatar
I got a question for you thats a little off the subject. When i go to shift my car the RPM's jump up to like 3000 RPM, completely randomly. It will stay at 3000 rpm by itself until i let the cluch out in the next lower gear. Do you think this could have anything to do with the MAF. I ask this cuz you really seem to know what you are talking about when it comes to annoying computer problems.
any added info would be greatly appreciated
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
