car starts...then dies!!!
Old Sep 29, 2006 | 06:49 AM
ArcticFuryLT1's Avatar
so this morning when i walked outside to jump in my TA i turned the key and the car started up just fine. not more than 5 seconds later...it just...dies! so i started it again...5 seconds later it dies again like the fuel was being cut or something. so i try again, it starts up, and doesnt die. i drove it a good 30 miles to work with no problems at all. then i get off work and now it won't start at all...and when it did start it would die after 5 seconds again. so after about a half hour of fighting with it, it finally stays running and i drove home with no problems whatsoever. i talked to my friend and he thinks it's an electrical problem...maybe a relay in the ignition or something. what do you guys think? i'm kinda stumped here...
Old Sep 29, 2006 | 07:11 AM
Sweetred95ta's Avatar
Re: car starts...then dies!!!
The fuel pump may be going out on you. Check the fuel pressure both when it is firing up and dying and when it stays running (could still be a little low).
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
