car starting issues
Old Oct 8, 2006 | 10:52 PM
cb94ta's Avatar
car starting issues
Well my ta has finally got me at wits end, it basically does nothing when you first turn the key after a few seconds sometimes a little longer it fires off just fine, but then once it gets hot it still hesitates but it also turns over for a little bit before it fires off I've replaced the starter, the fuel pressure regulator had gone out so I replaced it with an adjustable one I really don't know where to look from here to solve it any ideas?
Old Oct 8, 2006 | 11:01 PM
Josh'95Z28conv's Avatar
Re: car starting issues
Hows your fuel pressure during cranking?
Old Oct 9, 2006 | 11:32 AM
CALL911's Avatar
It almost sounds like you may have a bad battery. This could have been made dead by a bad alternater as well. Usually when one goes bad, it takes out the other as well. I would have them both checked before I would look too in depth in your car.
Old Oct 9, 2006 | 12:03 PM
When you turn the key "it basically does nothing"... you mean no click, no dash lights come on, starter doesn't crank, no indication of any kind that there is any sort of voltage present? Or.... you turn the key and the starter cranks, but the engine doesn't start for a few seconds?
When the engine is hot, it appears it does the exact same thing as when its cold???? ...no difference whether the engine is cold or hot????
When it finally starts running, how does it run.... smooth, rough, misfires????
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
