car sounds like a 2 step@ high rpm after cam install
Old May 2, 2004 | 12:40 PM
meangrn94ta's Avatar
i installed the cc305 cam and about 4500 rpm it sounds like im hitting a 2 step and i dont even have one. i tried replacing th opti with a used one that is in working coondition and the same problem still exsists. is it possible that the timing chain is off a tooth or two?
mike LaBarbera
Old May 2, 2004 | 01:13 PM
Dave88LX's Avatar
What do you mean by hitting a 2-step, the car is cutting out?
Old May 2, 2004 | 01:15 PM
cam install
yea it cuts out and it sounds like a 2 step and u would think things are cokming apart under the hood. i replaced the opti already too. have u had this problem
Old May 2, 2004 | 02:28 PM
Kain's Avatar
Check your coil and wires. I had about the same and the coil was bad over 5000 rpm.
Old May 2, 2004 | 02:46 PM
i'm running that msd blaster coil and i had heard that they do wierd things i i replaced it with one that i knew was good and it did the same thing
Old May 2, 2004 | 03:49 PM
Kain's Avatar
Check the coil to opti wire then, make sure its not acting funky.
Old May 2, 2004 | 04:08 PM
do u mean replay it with a stock one just to see if it fixes it
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Klypto
Jul 24, 2002 11:21 AM
