the car is slow
Old Sep 21, 2005 | 03:13 AM
Dansean1's Avatar
the car is slow
In the past two weeks I've noticed that my 94 Z28 A4 has become really sluggish. When I floor it the car wont even kick down, it just accelerates hard-I do have a new built A4, 2500 stall. Not even from a roll or anything will it throw me back in my seat like it used to.
At night I have seen the arcing on some plug wires and coil.
Theoretically, if the "spark" is not getting its entire energy of any kind to the cylinder, how much hp loss could occur? For example if three cylinders were not getting enough spark (or almost none), that could be easily 40 hp loss, no?
I have an exhaust at the manifold/head portion but that wouldn't affect too much?
I need to clean my K&N which is probably dirty after at least 8k. Also, I have "popping" and/or hesitation to shift at high RPM.
Any suggestions/advice?
thanks
Daniel
94Z28 A4, 2500, bolt ons. 14.3's @ 99mph... not right now
Old Sep 21, 2005 | 03:16 AM
Dansean1's Avatar
Re: the car is slow
by the way, thought I would add I have a stock coil with MSD wires. Car has 84k on it and the wires have been on for a good 10k+.
Daniel
Old Sep 21, 2005 | 10:02 AM
ChevyTuffD.A.'s Avatar
Re: the car is slow
Even one plug wire arching will cause the car to run like crap and U say u have 3??? You're losing more then 40hp there buddy. As far as your tranny problems go. I had a bad throttle position sensor on my car once and it affected the tranny pretty bad. It would rev too high at part throttle and then short shift on me at moderate throttle. Get those plug wires changed and I bet u notice a big differance.
Old Sep 21, 2005 | 03:44 PM
Dansean1's Avatar
Re: the car is slow
I figured my car is suffering. my gas mileage sucks right now, bad enough as it is in So. Cal.
I never thought about a bad tps. Thats a good point. The car has 84k, things can start to go bad.
Maybe its time for a new LS1.
By the way, what type of pacesetters do you have, part #, price, etc?
thanks
Daniel
Old Sep 21, 2005 | 03:53 PM
Z95m6's Avatar
Re: the car is slow
Do you mean you have an exhaust leak? if so that can cause a problem if its at the head. You shouldn't need to clean your filter after 8k, unless you are driving through constant dust storms or something.
Old Sep 21, 2005 | 04:59 PM
Re: the car is slow
thanks
Daniel
I bought my Pacesetters off of ebay. Just go there and type in Lt1 headers. Look through the listings and u should find them. They should be about $280 for the headers and y-pipe.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
cryptopsy
Aug 19, 2002 12:19 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
sc93
Jul 26, 2002 02:02 PM
