Car shuts off after idling
Old Jun 28, 2010 | 08:50 PM
94 Camaro Z-28's Avatar
I have a stock 94 Camaro Z-28. I was letting the car idle and after about 5 minutes of running, it started the run rough like it is running or two or three cylinders, then the engine lights comes on and the car shuts off. I try to start the car again and it will turn over, but not catch fire and start. What couse cause this problem, or what kind of diagnostics can I do to find the problem.
Thanks for your help!!
Old Jun 28, 2010 | 10:20 PM
CstIrnFst's Avatar
You answered it yourself. That engine light came on for a reason. Have it scanned for codes and that will point you in the right direction. If you have questions about the codes, come back and let us know.
Old Jun 30, 2010 | 02:47 AM
Fatdog2's Avatar
Maybe it gettin any gas.Have you changed the gas filter?(also might spray the intake with a little carb cleaner and see if that helps.)
Old Jun 30, 2010 | 05:30 AM
Before you start listening to Fatdog2, have it scanned for codes. Seems Fatdog2 was drunk last night (or so he claims in another post) and left a bunch of questionable posts.......
Old Jul 1, 2010 | 09:24 PM
Is there a device I can buy to scan the car for codes? I do not want to chance driving the car to the auto part store for them to check the codes and it cuts off on me before I can make it there.
Thanks!!
Old Jul 1, 2010 | 09:56 PM
You need an OBD-I scanner. AutoXray, Actron, etc. make them. Either OBD-I only, or more expensive models that will scan both OBD-I and OBD-II. Has to be a real scanner, and not the $30 Actron that is nothing more than a switch that shorts the ALDL pins - 93 is the last year that will work on (in spite of what it says on the box). Most auto parts stores only scan OBD-II.
There is also free scanning software available from TTS DataMaster and FreeScan.
Old Jul 3, 2010 | 04:48 PM
McLovin's Avatar
I had something like this happening to my car, turned out to be the opti. Get it scanned for sure before wasting money on parts you don't need.
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
