car quits when it goes to closed loop
Old Jul 29, 2006 | 07:38 PM
Blownbird355's Avatar
I have 94 Form car runs ok till it hits closed loop. tried unplugging maf to no avail. Whats normal map for SC car at idle? I can provide a DM file if someone would like to take a look.
Old Jul 30, 2006 | 12:57 AM
Re: car quits when it goes to closed loop
ttt
Old Jul 30, 2006 | 01:26 AM
bmwmcars's Avatar
post the datamaster...
but in the mean time, how do the o2s look?
Old Jul 30, 2006 | 02:53 AM
pretty bad actually lower mv. I need to look a little closer at the log myself. will post log tomorrow. thanks
Old Aug 1, 2006 | 01:09 AM
I have my files anyone want to take a peek?
Old Aug 1, 2006 | 05:31 AM
Guest47904's Avatar
Guest
I know what you're going thru. I have the same problem even after having cured one major defect. My driver side O2 was going full rich even with the engine off. Turned out to be a bad driver in the PCM. Changed the PCM and it corrected the problem with the O2 but it still runs like crap in closed loop. Open loop is fine.
I'm going to log it KOEO, then while it's warming up and finally when it goes to closed loop. Maybe there's something I'm missing.
Send me your data and we can compare
Old Aug 1, 2006 | 06:43 PM
sent
Old Aug 2, 2006 | 07:12 PM
ttt
Old Aug 5, 2006 | 12:43 AM
thanks for the help
Old Aug 5, 2006 | 06:05 AM
Guest47904's Avatar
Guest
Where did you send the data? I didn't get anything.
Old Aug 5, 2006 | 10:03 AM
The rolleyes was not meant for you but i sent you logs to your email you had listed on here on your profile.
Old Aug 6, 2006 | 08:16 AM
Guest47904's Avatar
Guest
Didn't get it. Send to the PM address.
MadMav
Feb 6, 2015 11:02 PM
fpete1992
Dec 11, 2014 03:51 PM
GhostZ28
Dec 7, 2014 11:53 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
